svíčky
Re: svíčky
su to o stupen studensie sviecky ako standard, su akurat vhodne pre tlak serioveho turba 1bar, odtrh elektrod nastav na 0.8mm ak je iny. Ja osobne ich tiez pouzivam.stiloman píše:mám svíčky BCPR7ES............mohou dělat problém?
kdyz uz se to nakouslo...raddy, ci ostatni znali....jake svicky by jste mi doporucili na muj SR20DET?
Kto by kupoval drahe platinove, ked uz nikto nema katNISMOO7 píše:PFR6A-11 NGK
No povedz skrz co este, nech sme mudrejsi (okrem intervalu vymeny co u nas tiez nema vyznam)NISMOO7 píše:NIESU TAM LEN SKRZ KAT.
Ale PFR su platinove nie iridiove. Ci sa mylim ? Iridiove su IQ, IV a tak.NISMOO7 píše: NAPR:U NGK:
STUDENÁ SVIEČKA NA VäČŠIE TEPLOTY NAPR 9
TELÁ SVIEČKA NA NIŽŠIE TEPLOTY NAPR 10
OBE SA CHOVAJÚ NAJLEPŠIE/ODPALUJÚ PRI INÝCH TEPLOTÁCH,
KDEŽTO IRIDIUM MÁ PRACOVNÝ ROZSAH ZA OBE A DOKONCA ZVLÁDA TEPLOTY VYŠŠIE AKO STUDENÁ ,NAPRÍKLAD
MOMENT TO AKO NASTAVIŤ ODTRH.........NEMYSLÍŠ KOMBINAČKAMI,ŽE NIE?!
NO PRAVDE JE ,ŽE SA KEĎ ZA ZANESIA "BORDELOM ,TAK JE PO NICH,
LENŽE VÝROBCA NEPOČÍTAL S TÝM ŽE SI ICH LUDIA NAMONTUJÚ DO MOTOROV,KTORÉ ZOŽERÚ 2L OLEJA NA 1000 KM,NIČ PROTI STARŠÍM MOTOROM,KTORÉ EŠTE ODVEZÚ DOMOV.
A ĎALŠIA VEC:NGK A ZVLÁŠT IRIDIUM MAJÚ ZTENŠENÝ DRIEK!!!TO ZNAMENÁ ŽE KEĎ NEAKÝ BLBEC TO ZAČNE DOŤAHOVAŤ VYŤAHANÝM KLÚČOM A DÁ SI NATO "EŠTE" AJ DLHÝ NÁDSTAVEC ,A KTOMU TO NEDOŤAHUJE VO VODOROVNEJ POLOHE/NIEKEDY MANÍCI NEMAJÚ VO SVIEČKOVOM KLÚČI ANO GUMIČKU KTORÁ BRÁNI TOMU ABY SA PRI DOŤAHOVANÍ KLÚČ DOTKOL IZOLÁTORA SVIEČKY/TAK HO PROSTE NAPRASKNE...TO SA DÁ PEKNE POZRIEŤ,ALE HNEĎ PRVÉ ČO POVIE KOK...VYJ... POZRITE ČO MI PREDALI ŠAK VôBEC NEJDÚ...... .A TO EŠTE NEHOVORÍM ŽE IRIDIUMKY SA DOŤAHUJÚ ASI OKOLO 12 NM KDEŽTO NORMÁLNE NGK /16/ KOLO 15-18 NM A VERÍM TOMU ŽE NIEKTORÍ SÚ STÁLE NAUČENÝ DOŤAHOVAŤ SVIEČKY JAK KOŇA!!
P.S .SAMOZREJME ŽE NEBUDEM MOTOVAŤ TAKÉ SVIEČKY DO OLEJNIČKY LEBO KEĎ SI POZRIEŠ STREDNÚ ELEKTRÓDU TAK JE FAKT MALÁ,Á KEĎ TI NETESNIA KRÚŽKY A VÁLEC MÁŠ UŽ TEK VAJCOVÝ :-D ,ŽE SA TI PALIVO ZMIEŠA Z OLEJOM TAK TO UŽ JE VÁŽNE DES! A NEDÁ SA TOMU HOVORIŤ MOTOR.....
PREČO SOM JA NIKDY NEMAL S NIMI PROBLÉM?PRE TIETO DôVODY ANI JEDNA REKLAMAČKA,A DOTERAZ TVRDÍM,ŽE TO NEBOLI VYHODENÉ PENIAZE.
S ÚCTOU NISMO07
S ÚCTOU NISMO07
Z-Club Bratislava
Ja utahuju svicky od lonskeho října jenom a pouze momentakem ¨NISMOO7 píše:NORMÁLNE NGK /16/ KOLO 15-18 NM A VERÍM TOMU ŽE NIEKTORÍ SÚ STÁLE NAUČENÝ DOŤAHOVAŤ SVIEČKY JAK KOŇA!!
20-29Nm dle servisniho manualu.
