Termostat pro olejovy chladic
Hledam vhodnej externi termostat na olej a narazil jsem na tenhle kousek od Improved Racing.
http://www.improvedracing.com/oil-therm ... p-212.html
Z popisu a hledani na netu nejsem moc moudrej na jakem principu funguje. Bimetal?
Improved Racing's oil thermostat is a universal solution that can be used with any oil cooler on any vehicle. The device's unique internal design - the result of over a year of research and development - ensures a low pressure drop by placing the valve mechanism out of the direct oil flow when the valve is closed. The thermostat also boasts one of the most compact designs on the market.
vmille
Re: Termostat pro olejovy chladic
Příspěvek od vmille »
bude tam klasicky bimetal ktery podle teploty uzavira nebo otvira prepazky do obtoku nebo do chladice je tak reseny i DW sendvic
akorat tenhle vypada podle zpracovani dobre, ze by mohl i fungovat
