P:predni cire lampi
Napsal: 03.01.2010, 14:04
od MIRIS
Re: P:predni cire lampi
Napsal: 04.01.2010, 00:35
od Xcriss
sakra pekna cena
Nemit v prdeli motor tak bych si popustil uzdu
Napsal: 04.01.2010, 04:59
od MIRIS
tak je kup,na aute se ti to nestrati
Napsal: 04.01.2010, 09:38
od Bart34
kurna....to jsem prosvih o chvilku...dneska mi asi posila PetrS14 pravou parabolu za 500...
Na tom mas fakt luxusni cenu...
Mit prachy, beru to hned.
Napsal: 04.01.2010, 10:06
od Bart34
Hele co na ne rikaj pecky? A muze v nich bejt aji normal H zarovka?
Napsal: 10.01.2010, 19:36
od MIRIS
UP
Napsal: 10.01.2010, 19:51
od MYSAK
Tyhle svetla mozna delaj paradu ale v noci bych s nima nikam nejel..asi proto ta cena ze?
Napsal: 10.01.2010, 19:58
už jsem to někde psal..měl sem číny za pár korun a i ty svítily 2x líp v noci než seriové hrůzy
Napsal: 10.01.2010, 20:49
od MYSAK
To verim taky mam ciry ale svetlo s cernou parabolou? to nemuze fungovat
Napsal: 10.01.2010, 20:54
třeba může... otázkou je jak
Napsal: 11.01.2010, 00:20
od Bart34
myslim ze tam jde panove o tu cocku ne?
Napsal: 11.01.2010, 00:57
od Bart34
Toto jsem nasel na netu. At z toho napise celkovej vysledek nejakej zdatnej anglictinar.
They don't use the black areas for reflection, those are projection lenses in the middle, and if you aim them right, they work fine... this is what I have read from other sites that use similar-sized popup lights.
Xano
Sep 17 2009, 01:45 AM
Generally yes, the projector lense is what should project the light, however the black housing does diminish the lighting. I used a set on my corolla that were similar (not 6x7's of course, custom fit composites, but same design from ebay) and literally my factory lights were much brighter with the same bulb.
Maxpow
Sep 17 2009, 08:03 AM
Not to mention they're hideous.
alundra
Nov 13 2009, 11:25 AM
Anyone tried z31 headlightz swap?
diegovlspeed
Nov 19 2009, 09:37 PM
QUOTE(Xano @ Sep 16 2009, 04:58 PM) *
yeah the black innards ones fail, they dont make the black reflective enough. I would only suggest black lights for corners and tails on cars where you can buy em that way.
Napsal: 23.01.2010, 21:06
od MIRIS
PRODANO.
