K: EBC
K: EBC
Zdravim, kupim nejaky EBC. Piste ponuky.
![Obrázek](http://carthrottle.parts/img/carthrottle-logo-1441913302.jpg)
Re: K: EBC
Roberto! prodává apexi AVC-R
Re: K: EBC
no to by som rad, bohuzial mi napisal ze je uz predane.
Re: K: EBC
tak to se omlouvám, mluvil sem s ním dva dny zpátky a říkal, že ho má.. tak ho musel prodat včera..
Re: K: EBC
Uvažuji o prodeji, ale nejsem zatím ještě rozhodnutý..
HKS EVC 5 black edition
Features:
-Integrated CPUs in each component (Display Unit, Control Module, and Stepping Motor)
-Digital and Analog Display
-Wide Screen Multi-display
-Intelligent Stepping Motor
-High Boost Capability: Stock boost all the way up to 250 kPa (2.5 bar / 36.25 psi).
-Easy Boost Set-up
-Separate A and B boost level settings
-Peak and Hold Function
-Peak hold function monitors and displays highest boost level attained to aid in tuning and performance.
-Scramble Boost Function
-Warning Function
-Stock Boost Return Function: When the EVC is turned off, the boost level setting will automatically return to stock (baseline boost).
-Wastegate Selection Functions: Can be used with either internal (swing valve) or external (poppet style) waste-gates.
-Dimmer Function
-Data Memory Function
-Data Lock Function: A security code can be inputted to protect against accidental changes in settings.
-Offset Function: allows users to adjust the boost response and stability (Only available on EVC with PSI meter type).
Ilustrační foto:
![Obrázek](http://i717.photobucket.com/albums/ww171/JonoPhilpott/BoostController.jpg)
Mám též origo krabici + manuál
Features:
-Easy Boost Set-up
-Warning Function
-Dimmer Function
Ilustrační foto:
Re: K: EBC
Tak pouvazuj
a aku si prestavujes cenu?
Re: K: EBC
Hop, Grasell neodpisuje ![bounce :bounce:](./images/smilies/icon_bounce.gif)
Re: K: EBC
Nejsi sam kdo to chce, je to namontovane v aute a musi prijed abych to sundal.
- Member
Re: K: EBC
přijet je to nejmenší stačí říci kdy a kde v še je jen na domluvě
Re: K: EBC
Sak prevzatie je najmenej ako pise vyssie. Chcel som sa len dohodnut ked uz si napisal ponuku.
Re: K: EBC
Apexi stale mam :-) cena 5 tis ..k odberu ihned v praze
- Member
Re: K: EBC
co je to apexi zač popřípadě dej foto
Re: K: EBC
Uživatelé prohlížející si toto fórum: Žádní registrovaní uživatelé a 45 hostů
