KA24 a uz DET
![Obrázek](http://i1122.photobucket.com/albums/l522/davey25/20120511_195414.jpg)
![Obrázek](http://i1122.photobucket.com/albums/l522/davey25/20120511_195432.jpg)
![Obrázek](http://i1122.photobucket.com/albums/l522/davey25/20120517_131639.jpg)
![Obrázek](http://i1122.photobucket.com/albums/l522/davey25/20120517_132928.jpg)
Suspension:
*Apex coilovers
Wheels:
*18” inovit (volk te37 style)
*37mm spacers on rear 25mm spacers on the front
Bodywork:
*Full kouki kit
*Full respray inside and out including door / boot shuts and full engine bay respray in genuine Nissan red (not the cheap off the shelve option)
*Mint kouki rear lights
Interior:
*Full kouki 180sx interior
*Nardi steering wheel (leather with red stitching)
*S13 red mats
*Sony stereo
*Battery in the boot
Engine bay:
*SR20DE
*Standard air box (I’m to pimp for a aftermarket intake )
*Aftermarket exhaust (not loud as it has a nice big centre box)
*Decat pipe
*5 speed manual
*Solid steering bush
*Abs removed
*Brake pipes relocated from the bulk head
*All holes welded up in the bulk head
*All holes welded in slam panel
*90% of the unused holes welded in the arches (only leaving the holes for the expansion tank if you wanted to use one)
*Relocated relay box
*Large new ally rad
*Large FMIC fitted (fills the space between the bumper and rad nicely )
A cena zhruba 140 000Kč
škoda, že nejedou obrázky. nechceš ty fotky někam reupnout?
čím dalej tym viac sa mi páčia tie blatníky s front smerovkou...
- 935Baby
Pěkné, jen ten motor je takovej nejakej divnej
Chybí tam vysavač
![blackeye :blackeye:](./images/smilies/icon_blackeye.gif)
divné, já vidím jen toto
![Obrázek](http://pic.photobucket.com/bwe.gif)
Já to vydím taky dobře
Tady je to přímo na DW foru http://www.driftworks.com/forum/drift-c ... nside.html
Hezká decentka. Co je to za ty prahy ?
Je to kompletní Type-X kit.
![Obrázek](http://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash4/402029_10150524052606415_512901414_8980743_267366376_n.jpg)
![Obrázek](http://i633.photobucket.com/albums/uu58/matocastor/DSCF0273.jpg)
A jak se dávají dopucu kola ?
![Obrázek](http://i169.photobucket.com/albums/u230/PeterTistaken/060c5d63.jpg)
Leštění límců.
![Obrázek](http://i633.photobucket.com/albums/uu58/matocastor/DSCF0232.jpg)
![Obrázek](http://i633.photobucket.com/albums/uu58/matocastor/DSCF0234.jpg)
![Obrázek](http://i633.photobucket.com/albums/uu58/matocastor/DSCF0241.jpg)
na DW fóru ty fotky jdou. pěkný.
A to čištění kol tady dole je taky moc :-D
![Obrázek](http://i1034.photobucket.com/albums/a430/azineakinadan79/CountyofHerefordshire-20120523-01004-1.jpg)
Spec list
(Engine)
VG30DETT (bored/honed ’20 thou)
Carillo ‘H’ beam rods
Arias oversized pistons
ARP bolts
Cometic gaskets *
Nismo 740cc injectors
300 degree fuel rails
SE ported and polished heads
SE cams/valves
AMS pulleys
ACL bearings
Polished crank
AMS manifiolds + gaskets
HKS turbo elbows
Garrett GT675 RS turbos
Polished water pipes
New OEM water pump/oil pump
EGR/PCV delete
NGK spark plugs
Unorthodox racing lightweight pulleys
Blitz custom exhaust (titanium wrapped)
Greddy 3 row front mount intercooler
ARC GTR oil cooler + braided hoses (front mounted)
Koyorad radiator
Nismo rad cap
CZP radiator hardpipe kit
ARC bov's
Greddy expansion tank
Greddy oil catch tank
Blitz oil filler cap
Greddy sandwich plate
Samco intercooler pipes/radiator hoses/vacuum hoses/intercooler couplers
SFS water/heating pipes
HKS twin induction kit/Samco elbows
AEM EMS
AEM 3.5 bar MAP sensor
Bosch 044 fuel pump
Accusump
(Transmission)
Carbonetic triple plate clutch + flywheel
Carbon one piece prop
Re-built OEM 5 speed gearbox
(Steering/Suspension)
Tein Type Flex coilovers
Tein EDFC
Driftworks front upper camber arms
Driftworks front lower arms
Driftworks Geomaster tension rods
Driftworks polybushes
Tein inner tie rods
SPL version 5 outer tie rods
SPL front drop links
Stillen front ARB
Driftworks HICAS replacement kit
Driftworks rear upper camber arms
Driftworks rear lower camber arms
Driftworks tension arms
CZP rear drop links
Stillen rear ARB
Ksport 8 pot brakes (356mm discs) front + braided hoses/Yellow Stuff pads
Ksport 6 pot brakes (356mm discs) rear + braided hoses/Yellow Stuff pads
(Exterior)
Satin black paintjob
Stillen GT-Z front bumper (modified)
Border vented fenders
Carbon fibre vented bonnet
Carbon fibre vented front panel
Carbon fibre fuel door
Carbon fibre aeriel delete plate
Carbon fibre cannards (front bumper)
Adjustable bumper support bars
Carbon fibre ‘Origin’ GT wing (formerly fitted to the Driftworks S15)
Aero-catches (rear hatch)
Stainless bonnet pins (bonnet)
Border JDM wing mirrors
CMS skirts
Flared rear arches
’99 spec rear lights
HID headlights
Scroth tow loop (FIA approved)
Red enamelled rear tow loops
17” Riverside deep dish split rims (10j & 9j) ET -7 (only set this side of Mars!)
(Interior)
Sparco Kevlar Pro 2000 drivers seat
OMP seat rails
Sparco Kevlar rally seat
Bride seat rails
Takata 6 point harnesses
ASD hydraulic handbrake + Willwood brake cylinder/pass through kit
Driftworks hydraulic brake lines
Personal steering wheel (Ltd edition OZ Racing)
Nismo GT gearknob
Autopower/Pegasus Auto roll cage (SCCA/FIA approved 1.75 inch x 0.120" DOM)
Carbing rear strut brace
HKS Oil temp/Oil pressure/Water temp gauges
Greddy 60mm (pillar mount) boost gauge
APEXi multichecker
Tein EDFC controller
Greddy Spec ‘S’ boost controller
Blitz AF meter
Lifeline 2ltr on board fire extinguisher system
Electric cut-off switch
jj to je muj sen mit tohle jako dailySilverFox píše:Ideální daily sx. Až na ten fake nardi.
![Obrázek](http://i31.tinypic.com/ifppqw.jpg)
Uživatelé prohlížející si toto fórum: Žádní registrovaní uživatelé a 78 hostů
