crash-test 200sx
crash-test 200sx
nemate nekdo crash-test na 200sx nebo 240 nebo tak neco ? docela by mne to zajimalo jakou sanci mas na prežii když to rosekaš........
- OndraS13
Re: crash-test 200sx
Když rozsekáš tak hezký auto tak se můžeš rovnou jít zabít joke
neee - zkoukni nějaký fotky bouranejch dvoukil !
Tady na téhle stránce máš něco málo o tom napsaný.
http://www.crashtest.com/explanations/archive/crash.htm
Year/Make/Model: indicates the year, make, and model that the crash test applies to even though a different vehivle may have been the actual vehicle used for the crash test. (Example: A 1990 Geo Prizm and a 1990 Toyota Corolla are twins and therefore share the same crash test results.) If you do not see the vehicle you are looking for, it may not have been tested or only its twin is listed.
Doors: 2Dr = 2 Door; 4Dr = 4 Door; CV = Convertible; HB = Hatchback; MPV = Multiple Purpose Vehicle; PU = Pick-Up Truck; Sd = Sedan; SUV = Sports Utility Vehicle; Van = Van; Wa = Station Wagon; Xcb = Xtended Cab.
Weight: is the weight in lbs. of the vehicle tested.
Driver and Passenger columns rate the crash tests by"stars" as follows:
Frontal Impacts only (Differs from Side Impacts)
5 stars (*****) = 10% or less chance of serious injury.
4 stars (****) = 11% to 20% chance of serious injury.
3 stars (***) = 21% to 35% chance of serious injury.
2 stars (**) = 36% to 45% chance of serious injury.
1 star (*) = 46% or greater chance of serious injury.
N/A (N/A) = incomplete or missing data.
Side Impacts only (Differs from Side Impacts)
5 stars (*****) = 5% or less chance of serious injury.
4 stars (****) = 6% to 10% chance of serious injury.
3 stars (***) = 11% to 20% chance of serious injury.
2 stars (**) = 21% to 25% chance of serious injury.
1 star (*) = 26% or greater chance of serious injury.
A serious injury is considered to be one requiring immediate hospitalization and may be life threatening. These stat ratings become meaningless if you do not use the restraint systems in your vehicle including the seat belts. See note at bottom of page which provides links to the original test data and briefly describes vehicle test procedures and the importance of vehicle weight.
The Results below are listed in the following left to right order: (F=Frontal impact; S=Side impact)
(All impacts are measured in the front seats except passenger side impacts which are measured in the rear seat.)
Year--- |Make and Model |Doors| Weight | Driver (F) Pass | Driver (S) Pass |
1980--- Nissan 200SX--------- 2HB-- 3038 (** ) (*** )
1984--- Nissan 200SX--------- 2HB-- 2880 (* ) (*****)
1987--- Nissan 200SX--------- 4Dr-- 3218 (** ) (**** )
1997--- Nissan 200SX--------- 2Dr-- 2746 (*****) (**** )
1979--- Nissan 210----------- 2Dr-- 2425 (* ) (* )
1989--- Nissan 240SX--------- 2HB-- 2680 (*****) (**** )
1995-97 Nissan 240SX--------- 2Dr-- 2765 (*** ) (**** )
1984--- Nissan 300ZX--------- 2Dr-- 3370 (**** ) (*** )
1991--- Nissan 300ZX--------- 2HB-- 3324 (*** ) ( N/A )
S13ka je na tom celkom dobre. U vodica este lepsie ako S14ka (hlavne kvoli hlave, nohy u vodica hlavne lava su na tom u S13 dost zle).
http://www.safercar.gov/portal/site/saf ... d17898RCRD
240sx mě svou tuhostí překvapila,když sem sní sroloval betonový plot a sloup..
Uživatelé prohlížející si toto fórum: Žádní registrovaní uživatelé a 130 hostů
