NISSAN SILVIA S13 180SX
The Nissan 180SX was a hatchback coupe (though Nissan marketed it as a fastback in most of its markets) based on the S13 chassis from the Nissan S platform, and sold only in Japan (although sold in some other countries under the 200SX name)[1]. It was sold as a sister model to the Nissan Silvia from model year 1989 through 1998. The S13 Silvia was discontinued in 1993, but the 180SX was successful enough to convince Nissan to keep it in the market for the full length of the next generation Silvia's tenure. The 180SX differed from the S13 Silvia in that it featured pop-up headlamps, and a fastback roof with a liftgate. Specifications and equipment were similar, however the naturally-aspirated CA18DE engine was not offered. [1]
The name 180SX was originally in reference to the 1.8 liter displacement CA18DET engine used in the chassis. In 1991, however, the engine was upgraded to a 2.0 liter model, offered in two forms: the naturally-aspirated SR20DE engine and the turbocharged SR20DET variant. Although the new engine was of larger displacement, the 180SX nomenclature remained. A common body modification to the 180SX and its sister car, the North American 240SX fastback, is the Sileighty conversion.
180SX was also a trim level of the S110 Silvia in Europe. The badges for this model read "Silvia 180SX", so this car is not properly a 180SX by model, but a version of the Silvia instead.
Other discrepancies from this standard were distributed to Micronesia and South Pacific islands, including LHD cars with 180sx badges and non-retractable headlamps.
Like the Japanese 180SX SR20DET discrepancy, European, as well as South African models of the S13 chassis were called 200SX though equipped with the CA18DET engine.
180SX Model Changes
An early model 180SX.The 180SX came in three major iterations, the first of which was released in March 1989 and the last of which ended production in December 1998.
The first iteration of the 180SX came in two versions called Type I (standard type) and Type II (advanced type). Nissan's HICAS II four wheel steering system was optional only on the Type II 180SX. All versions had the CA18DET engine with 175ps. 5 speed manual and 4 speed automatic transmissions were available in all types.
The second iteration 180SX was released in January 1991 and boasted several major changes from the first model. The biggest change was the adoption of the SR20DET engine with 205ps. Although the engine was larger than the previous CA18DET engine the '180SX' nomenclature remained. The brakes were enlarged to cope with the increased power as was the limited slip differential. The front bumper and parts of the interior were also redesigned for this model. Type I and Type II were once again offered with only trim differences separating the two. The 15-inch alloy wheels also changed in design from the first model. Nissan's Super HICAS four wheel steering was an option on all models as were 5 speed manual and 4 speed automatic transmissions.
The final 180SX, showing the revised tail lights, spoiler and rear trims.The second iteration was face-lifted in January 1992. Although the car largely remained visually and mechanically unchanged, an additional trim level called Type III was added. Electronic climate control and CD audio were also added as options.
An additional face-lift was performed in 1994, the trim levels were renamed to Type R and Type X, with Type X being the higher of the two. Overall the car remained almost unchanged however.
A finally face-lift to the middle model occurred in May 1995 with the addition of a drivers side airbag and a change of alloy wheels amongst other minor details.
The final iteration was released in August 1996. It boasted a revised front bumper, tail lights, 15-inch wheels and interior. The mechanical and safety package received minor changes, such as the addition of a driver’s side airbag, seat belt pre-tensioners, and some changes in the wiring and ECU that had little to no impact on the actual performance of the car. Three levels of 180SX were offered: Type X, Type S and Type R, with the Type S being the first 180SX to be offered without a turbocharged engine.
The Type X and Type R both shared the same 205ps engine and overall mechanical package however the Type R lacked many of the cosmetic additions of the Type X such as the rear spoiler, side steps and 15-inch alloy wheels. The Type S was powered by a naturally aspirated SR20DE engine with 140ps, but was otherwise very similar in mechanical and cosmetic details to the top of the range Type X. The Type S however did not have the option of Nissan's Super HICAS four-wheel steering system like the turbocharged models did.
The Type X and Type R ceased production in October 1997 however the Type S and an addition naturally aspirated model called the Type G continued production until December 1998 when all 180SX production ceased.
Takže až se příště budete bavit o Nissanu Silvia S13 už budete vědět, že se jmenuje 180SX protože k tomu "přejmenování" na 200SX došlo jen z důvodů kvůli homologačním řízení v některých státech (typicky Evropa a jižní Afrika)
180SX Model Changes
http://www.advracing.cz
http://shop.ecumaster.cz
Re: NISSAN SILVIA S13 180SX
taže Silvia s13 je 180sx a přejmenovali to na 200sx..mno mazec
ale nevim,proč qůli homologaci měnili název..to fakt nechápu
zřejmně v době kdy homologovali model s13 s CA18DET pro Evropu a v Japanu v té době už do toho dávali SR20DET tak už tušili, že i další modely jako S14, S15 budou mít SR20DET. Tak se rozhodli, že udělají takzvané "typové schválení" na NISSAN 200SX pod které schovají jak 180SX tak i další modely které v budoucnu přijdou. Ono takové typové schválení je poměrně složitá a také drahá záležitost a proto i výrobci aut se snaží ušetřit kde se dá.Fogi píše:taže Silvia s13 je 180sx a přejmenovali to na 200sx..mno mazec
V japonsku se opravdu běžně používá označení 180SX pro model s CA18DET a 200SX pro model s SR20DET ... tím je jasné co je co a oddělí se zrno od plev. Je velká škoda, že se nerozhodli prodávat i v Evropě model s SR20DET, byla by to hned jiná klasa.
co je za problém tam ten SR20 strčit leda papírovej
Nevím asi je to problém.... nebo kolik z lidí v ČR to udělalo ? Někdo určitě, ale že by to bylo běžné se nedá říci.blázen píše:co je za problém tam ten SR20 strčit leda papírovej
viděl bych to na problém v nedostatlu motoru SR20DET na českém trhu.. kdyby se jich tu válelo plno,nikdo CA18DET ani neopravuje..evo400 píše:Nevím asi je to problém.... nebo kolik z lidí v ČR to udělalo ? Někdo určitě, ale že by to bylo běžné se nedá říci.blázen píše:co je za problém tam ten SR20 strčit leda papírovej
Před rokem jsem scháněl motor SR20DET do AE86tky a do 14ti dnů jsem ho měl. Nyní jsem scháněl S14tku kvůli blbostem kolem přestavby řízení a také mám další SR20DET....
Takže nemyslím, že by to byl reálně problém. Spíš bych to viděl na jinej problém. Tady pro nikoho není nic problém až do okmažiku kdy se to má stát. V imaginární rovině je každý mistr světa amoleta, nic není problém. Pak nastane situace kdy má něco řešit a už to najednou nejde. Jasně u S13tek je ještě jeden problém, cena toho motoru často převýší hodnotu auta a nědky i dvakrát a to se bavíme jen o motoru, teď ještě také precizně přestavbu provézt a nakoupit nové díly na "opravu" před pouhým vložením.
za tu dobu co sem chodím,sem tu neviděl víc jak 5 SR20 naprodej.. takže bych to jako problém viděl..CA18 seženu za 10minut sevším všudy.. tím netvrdím,že se nedá SR20sehnat.. ale tady jich opravdu mnoho není.. s cenama souhlasím.. stojí to poměrně dost
- mrkevvzime
evo ty si ty svoje kecy proste nemuzes odpustit to bys asi umrel, ze jo?
nic ve zlem nechci zacinat dalsi flame, ale kdyz se ti tu nelibi a vsichni tady maji jen plnou hubu kecu a skutek utek tak proc sem chodis to nechapu...
evo..podle mě se to mnohým ani swapovat nevyplatí.. většina ze zdejších lidí,nechce zacházet do nějakých výkonových extrému..do těch 300-350hp je podle mě ten SR20DET vcelku zbytečný..bude určitě pružnější..ale jako překážku k cílu většiny lidí,bych SR20DET neviděl.. je to jen otázkou priorit..ano chci silné a hodně rychlé auto..bude lepší pořídit SR/RB motor.. chci auto,které bude schopno pojet většinu aut v provozu..stačí CA18DET
- mrkevvzime
BTW par lidi tady dela RB aspon myslim, ze jsou aspon 2
a Kentoya dela 180sx mozna jeste nekdo, ale ted nevim
a jak rika Blazen CA vetsine lidi vykonove staci
A koho by jsi pak urážel ?mrkevvzime píše:evo ty si ty svoje kecy proste nemuzes odpustit to bys asi umrel, ze jo?
- mrkevvzime
ja nemusim urazet nikoho a ani nechci, fakt to nemam rad, ver mi, ale proste mi vadi kdyz sem nekdo prijde a skoro pokazde se navazi nebo nekoho jak rikas urazi, machruje atd. a ted nemyslim jen tebe...
to to fakt nejde bez toho
prosiiim
prosiiim
nějak nechápu problém s těma motorama proč tam swapovat SR motor, na foru je jich deset a z toho pět bylo KO, je to stejný jako u CA, jen místo na klice odchází na vačkách a CAčko pokud se u něj vyřeší odvětrání bloku a ještě pár kravin které se mi tu rozepisova nechce, tak je problém s klikou poloviční, je pravda že SR je novější, ale ty dvě deci nejsou až tak závratné a díky litině u CA bloku jsou si ty motory celkem rovnocenné
Když už swapnout do S13 jiný motor, tak jedině RB. SR za to sraní nestojí v poměru cena / výkon imho.
Uživatelé prohlížející si toto fórum: Žádní registrovaní uživatelé a 134 hostů
